My Lui 125 conversion
+13
zefarelly
vegagirl
17 posters
Page 5 of 11
Page 5 of 11 • 1, 2, 3, 4, 5, 6 ... 9, 10, 11
Re: My Lui 125 conversion
that should look cool snails.cant beat a bright vega and cut down handle bars are the bees knees
NIGE- Posts : 190
I've been making slow but steady progress - I had a bit of an issue with the front wheel being wonky (caused by some damage i'd inflicted to the bracket holding one of the lower fork rubber buffers) but hopefully that's fixed now.
Should have it on two wheels in the near future with any luck
tut tut, legsheilds before forks
Really?
Doh!
I was just testing to make sure they fit ok
As i was saying (cough cough) I should have it on two wheels in the near future with any luck
Back on its wheels at last
Now the last really tricky bit - getting the wiring loom sorted
I'm a bit worried about how wasting paint is to chip , it seems much easier than the last one I got
you must like a challenge snails, the loom will be a pain to put in with the engine in place
Lol I guess it will although I need to get one custom made so I need the engine in to work out dimensions I think
custom made loom? why ?
Well because of the fact that my old loom is a Lui one and intend to fit a rear brake light activated by front and rear brakes, a vega light housing so I can have full and dipped beam and lastly because of the electronic conversion and that I have changed the position of the junction box - see my post on LCGB forum - but thinking about it on the way home from work I'm wondering if I can get away with a Vega one.
To answer this question I could really do with seeing where the loom goes to fit the junction box on a Vega. Any pics by anyone would be appreciated
I intend to fit a LED brake light to a lui light unit so the loom may need some modification at the back light too I guess as a Vega had a single duel filament bulb.
Talking of which am I right in thinking that the loom on a Vega comes out from under the rear mudguard and then to the junction box? If I used a Vega loom and routing I think these would too short.
Also is the loom not crushed by the mudguard? Or is there a hole in the frame or mudguard for the loom to pass through?
the loom does come out from under the rear mudguard to the junction box.
be aware mate that the loom also come out of a hole where the engine mount spindle is, I had an early lui frame many years ago, and that hole was not present
Why does that not surprise me.
Why why why did thry bother
Mine has the hole you mention it also used to have some wires that passed under a frame strutt now that I think about it. That connected to the flywheel cover. I hope that this is not normal on the vega or I could be lifting my leggies!
Any chance you could measure the length of the cables from rear mudguard to, is it the coil? Or a junction box?
hate to be bearer of bad news snails, but the loom does run under the legsheilds and on top of the rear left strut and then front left then goes up to the fork stem from inside of the legsheilds.
https://lunaownersclub.forumotion.com/t34p75-latest-project
look at pics on page 6 and 7, they might help matey.
Thanks Daz, that's alright regarding the bad news, once you have put it together and then taken it apart again a few times you get really quick at it
Do you think you could measure me the loom length from mudguard to junction box/coil? No huge rush as I have other thing to sort that will keep me occupied.
loom
It's far easier to make a loom and use the thinwall cable,you only need 4 wires ,ignition,main feed to lights ,horn and brake switches ( T - offs) another for rear light feed and one more from brake switch to rear light. Then you only have the one wire coming from the regulator.
wack 63- Posts : 74
You I think you are probably right Wack
I have drafted up this as a wiring diagram. Any thoughts positive or negative welcome.
I've based most of this on my old wiring from the Lui which worked as far as getting the engine running, the parts I have and what Wack and Daz have given me as information. I've tried looking at a Vega wiring diagram but that justt servers to confuse me even more!
The bit i'm least sure about is the blue from the regulator connecting up with the brown from the horn but that's what I did with the Lui as it only had three wires from the headlight - brown, black (to rear light) and green (to coil obviously)
Oh and thinking about my diagram I've realised that I need some way of powering the rear light and brake light separately as I will not be using a duel filament bulb like in a Vega but a Lui rear light with the addition of a LED for the brake light. I've no real idea of how to do that either.
you don't do things the easy way snails do you.
Lol no. I just wish I'd bought a Vega!
What do you think? Looks good? Or don't know? I might throw the question up on the LCGB forum. There's some pretty clued up electrical bods on there.
throw it over to the otherside snails, the led's generally work better with dc current, I dare say someone will be able to draw up a loom for you to follow.
My LCGB forum post for anyone interested
http://www.forums.ilambretta.com/viewtopic.php?f=2&t=43334
Page 5 of 11
