My Lui 125 conversion
Page 1 of 11 1, 2, 3 ... 9, 10, 11  Next
Post  Snails on Mon Jun 28, 2010 3:58 pm
Bought this a couple of years back
Its a lot more shabby than it looks in the picture
To be honest I didn't realise the real differences between the Lui and a Vega and because it was so slow decided to up it from 50cc to 125cc before doing the frame.
engine out
strip
flywheel holding tools are not easily available
parts sourced
barrel mod. Cut the skirting off a cento barrel before rebore to 125 because its too thin
rebuild
holding tool made from J range rim which is slightly bigger and just fits
engine cowling modification to stop bottoming out of frame on engine
mudguard shortened to clear inlet manifold. Not sure I actually needed to do this but no harm done.
might fit this nice little pipe Very Happy
Anyways this is as far as i've got so far. Once I have the engine back in I intend to get it running and maybe off the sorn and mot'ed for a short while before I start on the bodywork and stuff. Problem is I started on doing an electronic conversion shortly before moving to a house 'in need of some modernising' and having a second child, so its not be touched for some time.
I'll post some progress pictures if I ever get things moving again
Re: My Lui 125 conversion
Post  daz.h on Mon Jun 28, 2010 4:23 pm
Evil or Very Mad these family and houses have a terrible habbit of getting in the way of things dont they Very Happy
good luck with the conversion.
Post  Snails on Tue Jun 29, 2010 6:31 am
Thanks Daz. Cant wait to at least attempt to get it running. With hindsight I wish I had not started on Electronic conversion.
Post  daz.h on Tue Jun 29, 2010 6:35 am
Snails wrote:Thanks Daz. Cant wait to at least attempt to get it running. With hindsight I wish I had not started on Electronic conversion.
why is that mate? are you going 6volt or 12 volt electronic?
i think electronic is the way forward.
Post  Staffy (Gareth) on Tue Jun 29, 2010 6:46 am
I was going to get a 12 Volt Electronic kit done by Jem before he did a lord lucan a few months ago Rolling Eyes
Post  Snails on Tue Jun 29, 2010 6:58 am
Just cos it means I have to wait even longer. I know its probably better in the long run
So far I have all the parts needed apart from the luna stator plate to fix the electronic stator to. I'm still trying to work out whether I can use my old lui one rather than finding a vega one.
I have drilled out the boss from both the AF Flywheel and the Vega Flywheel. I did the AF one first and its not as good a job as the latter one and I think I may have to drill them out again because some are a little ovalised. Problem is the pillar drill is round my mates house and I just cant seem to find time to go round and finish the job off.
Post  vegagirl on Tue Jun 29, 2010 7:22 am
Staffy (Gareth) wrote:I was going to get a 12 Volt Electronic kit done by Jem before he did a lord lucan a few months ago Rolling Eyes
i hope Jem is OK, haven't heard from him either Neutral
vegagirl
View user profile http://www.lunabase.co.uk
Post  daz.h on Tue Jun 29, 2010 7:29 am
seems like were all in the same boat Sad
i sent him a message on lcgb site and its gone from my outbox, so i assume he got it.
on a note i know sausage of sausagespeed can do these conversions, might be worth trying him?
Post  Snails on Tue Jun 29, 2010 7:56 am
Oh yes he did the nice one in scootering this month
Post  daz.h on Tue Jun 29, 2010 3:35 pm
how you intending to mount the electrics?
here is mine, i will need to add a regulator, but can do that easily as i have a small one (regulator that is Wink )
Post  Snails on Wed Jun 30, 2010 6:32 am
I have not really given it too much thought as yet. My general plan was to get some sort of bracket fabricated and fit it roughly where yours is. Mine being a Lui used to have the coil attachted to the flywheel cover if I remember right. I'm planning on using a ducati regulator and coil
what is that round black object?
Post  daz.h on Wed Jun 30, 2010 7:55 am
electrical junction box and rubber cover.
Post  Snails on Wed Jun 30, 2010 9:01 am
Where are you going to fit the regulator?
Post  daz.h on Thu Jul 01, 2010 4:12 pm
Snails wrote:Where are you going to fit the regulator?
probably under the coil, the regulator is only small, from a varitronic.
Post  Snails on Fri Aug 13, 2010 3:08 am
Wow. I actually found the spare time to go round my mates and finish drilling out the bosses on my flywheels. Made a bit of a pigs ear of the AF one I did first as some of the holes are quite ovalised. The Vega one I spent a lot more care making the centre punch for the first drill dead centre and the results are much better. Matching the AF flywheel to my vega boss and everything lines up ok so I'm just going to have a go at bolting it together. I did want to tap and die the threads but cant now. The alternative would be to drill out all the holes again with a larger drill bit but I think I would be up to 10mm for this so I think I will just see how it goes and hope it does not shake itself apart. Lots of locktight I think! Very Happy
As far as the keyway goes I lined the boss up so that the keyway was pointing to the same position as the old AF boss was. Hopefully this is the correct way to do it?
Once its bolted together next job is to get it lathed.
Post  zefarelly on Fri Aug 13, 2010 9:44 am
I used to make PX based electronics for Lambrettas in the late 80's by drilling, tapping and nylocs, it does work, I did wonder whether the PK vespa stuff might fit in a vega
from memory (fading fast) the hard bit is getting all the coils off the stator plate and on without damaging them.
zefarelly
View user profile http://www.throbnozzle-racing.co.uk
electronic
Post  joeyfont on Fri Aug 13, 2010 2:43 pm
...did this conversion a while ago....well worth the effort,posted on lcgb site.
i think you may have got the boss in wrong position?
the pick up is at 11 o'clock so the triggers in flywheel need to be over it and the piston needs to be nearly at tdc...? so i seem to remember keyway was at about 4 o 'clock...hope this helps... try to view lcgb post...pic's on there i've deleted from my files....good luck
joeyfont
Guest
125 conversion electronic
Post  joeyfont on Fri Aug 13, 2010 3:05 pm
...keyway at 11 o'clock ish....[not 4]
joeyfont
Guest
Post  Snails on Sat Aug 14, 2010 1:20 pm
joeyfont wrote:...keyway at 11 o'clock ish....[not 4]
pick up/flywheel timing mark note keyway @ 11 o'clock
also original timing mark arrow is now @ 6 o'clock :?
Obviously this picture shows it at 11 O clock but what its in relation to? Your timimg mark? I have not made a mark before taking them apart. Could I just position it the same in relation to where the -> arrow (not your marker one the embossed one) is on the flywheel?
Sorry if this is me being a thicko! Never did quite get my head round setting timings and stuff!
j125 electronic
Post  joeyfont on Tue Aug 17, 2010 12:53 pm
...forget about where all the bits used to go....
what i did was found the keyway position when the points started to open = 11 o'clock before tdc
put the boss on crank,then line the electronic flywheel up with pickup timing mark,bolt flywheel to boss... No study scratch Rolling Eyes affraid Very Happy
joeyfont
Guest
Post  Snails on Fri Sep 17, 2010 2:29 pm
Right got the mag back from the engineering place round the corner
next step is to butcher a pk and vega stator and try to make one new one
Post  daz.h on Fri Sep 17, 2010 2:32 pm
that looks well done.
Post  Snails on Fri Sep 17, 2010 2:36 pm
I just plan to drill out three holes on the back of the stator and hopefully all the coils etc will lift off as one
Post  Snails on Fri Sep 17, 2010 2:38 pm
daz.h wrote:that looks well done.
I hope so - not had chance to offer it up to the casing yet. Also I hope none of them bolts come loose as think it would make a hell of a mess of things. Thinking of using strong locktight once I know the key way is in the right place
Post  Snails on Sat Sep 18, 2010 8:53 am
Damn dosent fit can someone measure there's and give me a diameter?
