j125 Kickstart & lui seat
Im after a J125 kickstart and a standard Lui seat if anyone has them.
Cheers
Cheers
Re: j125 Kickstart & lui seat
I think I got a j125 kicker left - is that of any use on the Luna line???
Cheers, it is for me as i have a 125 Starstream engine with its carb and funnel filter already fitted in a Lui 50CL i have picked up today
It has a pipe on it thats just, well wrong and in order for the pipe to be on it then the kick start has been removed as it wouldn't have room to be used with the daft pipe it has. It looks like it would have been bumped to get it to go whenever it went last (a couple of years ago).
body work and paint is good but it needs a bit of work in terms of the engine (full strip, perhaps change of bearings, seals, clutch plates maybe etc and a general lubrication and final check) then the electrics sorting as the cable looms in place etc but the coil and junction box aren't fitted (saying that there is an original coil in a box of bits i have had with it so who knows.
i will need to buy a J125 Starstream exhaust from somewhere (any ideas anyone) and see how it goes.
On my kickstart the bolt snapped off and 'till now I'm not in the mood to get the drill to remove it.
Anyway this one is going cheap I think:
http://cgi.ebay.co.uk/scooter-enginge-casing-lambretta-/280680565651?pt=UK_Motorcycle_Parts&hash=item4159dd8b93
» You reed valve conv guys
» kickstart lever wanted
» kickstart shaft needed
» j125 3 speed nos crankshaft
» Vega 4 speed layshaft - j125 starstream layshaft..?
