electronic kit
+3
shand
7 posters
Page 1 of 2
Page 1 of 2 • 1, 2
electronic kit
Good Afternoon
Has any body fitted one of the Tino Saatchi electronic kits, if so did you have any problems, I tried to fit the flywheel and it binds on the stator plate fixing screws, these are the ones that came with the bike and to be honest they are quite chunky, any recommendations on what type of fixing screws to use
Cheers
Cheers
shand- Posts : 64
Re: electronic kit
personally, I would not use any other screws, I'd take it back, if it does not fit with what's supplied then it should not have been sold, I dare say also if something goes wrong and you take it back under warranty, if you've not used the right stuff it could invalidate the warranty.
Re: electronic kit
Screws weren't supplied with the kit Daz, they are Phillips cheese head screws, out of interest do you know what type of screws and washers should be fitted
shand- Posts : 64
Re: electronic kit
Try some M6 Allen screws http://www.ebay.co.uk/itm/M6-6mm-A2-Stainless-Steel-Flanged-Button-Head-Bolts-Hex-Socket-Allen-Screws-/360669006362?pt=LH_DefaultDomain_3&var=&hash=item53f98c4a1a Can't remember what length you need .
wack 63- Posts : 74
Re: electronic kit
there good what wack suggested as they have a lower profile, not sure of length without going in the shed
Re: electronic kit
Hi Shand, I have just put a Varitronic on the Vega & the Flywheel would lock onto the bobbins on the Stator when I tightened the flywheel down. I phoned a few dealers who sold the kit but to be honest none gave me a confident answer to the problem, so I had the Mag housing face milled down 3mm to give me clearance, problem solved. My understanding is the Varitronic doesn't use a black box pick up like a normal electronic, so it's not so critical about distance as there aren't fingers on the flywheel to line up with a black box. It seems the spark & timing are controlled by the coil. As for the screws, I just use 6mm x 20mm button Allen bolts & thin washers (thou Wacks bolts would do the job nicely). I hope this helps & makes sense....Steve
Re: electronic kit
Changed the screws and fitted a new woodruff key fitted the flywheel, started to torque it up and the flywheel nut shit itself, it was all free up to that point so I may be ok. The kit came with big spring washer are you supposed to use this instead of the wavy washer cos I didn't, anyway job stopped till I get a new flywheel nut
shand- Posts : 64
Re: electronic kit
Bugger I didn't see a spring washer in mine? I just used a wavy washer. Seem to have no issues & I've had it on & off a few times, I also lapped the flywheel to the crank. I must admit I've seen some nuts that look like they are made of cheese Hope you get sorted...
Re: electronic kit
Thanks for the reply, I'll order a new flywheel nut and wavy washer and I'll invest in a decent 6 sided socket and see how I get on
shand- Posts : 64
Re: electronic kit
myself and dad had same problem on his VEGA we ended up changing the standard bolts holding the stator with some spear BGM bolts and it worked perfectly done thousands of miles on it and no problem
VEGA luke- Posts : 34
Re: electronic kit
Thanks for that Luke, I'll have to wait till the new flywheel nut comes to see if the issue has been sorted, did you fit the cdi and regulator in the same place as the old coil and junction box
shand- Posts : 64
Re: electronic kit
yes but bit untidy the best way to do it would cut a hole in the frame like trotsky has on his project
https://lunaownersclub.forumotion.com/t845p45-latest-project
Re: electronic kit
I'm afraid work like that is beyond me I've made a bracket to stand the cdi off so it clears the cowl and a small plate for the regulator to tuck it up into the frame, then a bit of jiggerypokery with the wiring, then all I need is the flywheel to fit, time it up and that should be it
shand- Posts : 64
Re: electronic kit
Well my piss is well and truly boiling, I seem to have the same problem as Trotsky, the flywheel is fouling on the bobbins that the coils are wound on. I'm not that much of an optimist that I thought it would be plug and play but I didn't expect to have to take it apart an get it machined to make it fit
shand- Posts : 64
Re: electronic kit
in the past I have cut down the plastics on the sides of stator coils to prevent fouling, but as I said previously, I'd take it back.
Re: electronic kit
shand wrote:Well my piss is well and truly boiling, I seem to have the same problem as Trotsky, the flywheel is fouling on the bobbins that the coils are wound on. I'm not that much of an optimist that I thought it would be plug and play but I didn't expect to have to take it apart an get it machined to make it fit
For the money these cost I would want it to work out of the box. I know things are difficult to design for lammys because of all the variations, pattern parts etc but its not exactly cheap.
Re: electronic kit
I'm getting the mag housing milled at work, I contacted scootercenter, told them about the problem and they requested photographs which I've sent but as yet I have had no reply. I would prefer to use dealers in this country but there aren't many with a stock of vega spares so you can can end up using 2 or 3 dealers for 1 order which in turn doubles or trebles the postage and scootercenter were considerably cheaper than the only uk dealer who had them in stock. I really want this to work otherwise I probably would be going down the give me my money back route
shand- Posts : 64
Re: electronic kit
trotsky i have a varitronic electronic ignition that i am going to fit later in the year,it is labelled "lunatronic lui 50/75 j 100/125 is this the same type you fitted because i was wondering if i will have to get the mag housing milled also.....mick.
li mick- Posts : 100
Re: electronic kit
Mine came in plastic case and its marked lunatronic on the flywheel
shand- Posts : 64
Re: electronic kit
mine is marked lunatronic lambretta.it on the flywheel and also came in a plastic case so it looks as if i will have the same trouble?shand wrote:Mine came in plastic case and its marked lunatronic on the flywheel
Re: electronic kit
Hi Mick, mine has this on the Flywheel. I can't say if you'll come across the same issues as myself & Shand? Others must have this kit on but I haven't seen anything about the woes we're having posted anywhere. The only good thing is that if you do come across the same issue, is that a solution has been hopefully sorted (thou as Snails said, it should all fit out the box)!! I'm sure Shand will post his outcome once he has rectified his problem & this will help others going forward...Steve
Re: electronic kit
trotsky wrote:Hi Mick, mine has this on the Flywheel. I can't say if you'll come across the same issues as myself & Shand? Others must have this kit on but I haven't seen anything about the woes we're having posted anywhere. The only good thing is that if you do come across the same issue, is that a solution has been hopefully sorted (thou as Snails said, it should all fit out the box)!! I'm sure Shand will post his outcome once he has rectified his problem & this will help others going forward...Steve Thanks Steve im looking forward to trying this out and its good to know that it will have been tried and tested before i start my convertion and yes it looks like the same flywheel
Re: electronic kit
Mag housing is now milled, timing marks checked, lapped the flywheel to the crank nice matt finish with no high or low spots, just need a mag side oil seal and a new flywheel puller then fingers crossed........
shand- Posts : 64
Re: electronic kit
Right got it together, started nice and easy , strobed timing ticking over at 23 degrees retarding to 17 at three quarter to full throttle, does this sound about right
shand- Posts : 64
Page 1 of 2 • 1, 2
» My Lui 125 conversion
» Electronic conversion
» Electronic Ingnition (Lunatronic)
» Electronic bulb watts and stuff
» Ducati Firefly electronic ignition
Page 1 of 2
