LUNA OWNERS CLUB
Would you like to react to this message? Create an account in a few clicks or log in to continue.
Possible to use sunny crank for conversion??
Possible to use sunny crank for conversion?? Empty Possible to use sunny crank for conversion??
Post  Raffspeed Thu Dec 17, 2015 1:28 pm
I've been trying to get hold of a starstream or j125 crank without any luck. Scooter restorations have some SIL cento/sunny ones going cheap and I was wondering if I could modify one to use???
Raffspeed
Possible to use sunny crank for conversion?? Empty Re: Possible to use sunny crank for conversion??
Post  daz.h Thu Dec 17, 2015 1:33 pm
not sure on the difference in the sunny to j range cranks, but Paul at scooter restorations will.
the j125 and starstream cranks are different, you can't put the starstream crank in a lui casing, only a j125 crank, the opposite applies to a vega casing.
Post  Raffspeed Sat Dec 19, 2015 4:11 am
From what I can tell it's the length of the spline that is different on all of these cranks. I'm gonna buy a few off scooter restorations and see what I can do by grinding off the case hardening, putting some weld over the top and then machining it to match a 4 speed j125 one. They're only round 40 quid a pop so I won't be out too much coin if it goes tits up...
Raffspeed
Post  daz.h Sat Dec 19, 2015 3:55 pm
keep us informed of how it goes.
Post  madmaex08 Wed Feb 17, 2016 7:56 am
any news? Possible to make it work?
madmaex08
Post  trotsky Sat Feb 20, 2016 1:44 pm
Hi, yes you can modify a Sunny crank. The differences are the Sunny ones are Full circle webs (Not an issue) & the rod on the sunny uses a 14mm small end, so no good for j125 pistons (the pin & rod lengths are the same). Also the shoulder on the drive side web needs machining back to take the wider Drive side bearing (4mm I think), see link https://lunaownersclub.forumotion.com/t515-will-it-work for a visual example. No issues on the flywheel side, just use the 3 piece mag & ancillaries
Casa now do a Starstream Con rod kit & Cookie at Chiselspeed can do the Rod & shoulder mod. Hope this helps.....Steve
Possible to use sunny crank for conversion?? Sunny_Crank_011  Possible to use sunny crank for conversion?? Sunny_Crank_014  Possible to use sunny crank for conversion?? Sunny_Crank_001     Possible to use sunny crank for conversion?? Sunny_Crank_015  Possible to use sunny crank for conversion?? Sunny_Crank_007
Starstream Crank Webs  Possible to use sunny crank for conversion?? 100_1484
