will it work ?
will it work ?
Post  littlemoon on Thu Jan 31, 2013 12:51 pm
Cool
Re: will it work ?
Post  Thackers on Thu Jan 31, 2013 12:56 pm
Can't see why not, you going to use that saw blade as a wheel too? Straight out of Wacky Racers Wink
Re: will it work ?
Post  Snails on Thu Jan 31, 2013 2:38 pm
Will it fit more like!
Re: will it work ?
Post  wack 63 on Sat Feb 02, 2013 4:52 pm
Very nice but will the crank be man enough and the wheel fit?
Re: will it work ?
Post  littlemoon on Sun Feb 03, 2013 1:20 pm
new crank is on its way(will have to change the rod from 95mm to 105mm), might even have it tomorow. so crank strength should be ok. i will need a couple of mm taking off the reed stuffer and about 5mm off the inlet manifold flange to clear the back wheel i will be welding on a packer plate whicch will be pre drilled and have the transfers cut in to it. i would have to build the case up around and in the tranfers anyway so doing a pre done packer a welding on will be easier. i think the wheel clearance will be the main issue
Re: will it work ?
Post  daz.h on Sun Feb 03, 2013 3:07 pm
Twisted Evil
still wish i'd gone the rd80 lc route, nice small barell, reedvalve, easy to get parts. Rolling Eyes
Re: will it work ?
Post  littlemoon on Mon Feb 04, 2013 4:06 am
daz.h wrote: Twisted Evil
nowt to stop you daz Laughing . i took a chance on this kit as i have a polini smallframe kit , stud spacing and spigot where in the right ball park ,crank induction was the big drawback. so when i saw a secondhand but nearly new smallframe parmakit 130cc reedvalve kit on ebay i thought this could work Shocked . fingers crossed and 16bhp anyone. oh and i might have solved the lack of starstream cranks aswell . will know this aft or tomorow so fingers crossed for that aswell. i only got a limited amount of info on the cranks so i bit the bullet and bought one Shocked . the only thing that gets in the way for me is a lack of time, so i have to cram as much in as i can . cheers simon
Re: will it work ?
Post  daz.h on Mon Feb 04, 2013 3:43 pm
its finding them starstream cranks thats a big issue.
hope your news is good.
16hp on a vega Twisted Evil
Re: will it work ?
Post  NIGE on Tue Feb 05, 2013 2:49 am
just got over the flu not had a look on site for weeks.wow simon .this might be of some help .the starstream i have seen with this kit on.the reed valve is pointing the other way .to the frame not the wheel. it will work and you will have the fastest luna in the world using a j range engine brilliant stuff simon.i will still race ya Twisted Evil Razz
Re: will it work ?
Post  littlemoon on Wed Feb 06, 2013 1:54 pm
daz.h wrote:its finding them starstream cranks thats a big issue.
well its good news on the cranks, only a small mod is needed and a change of rod is required. the rod thats in the crank looks like its hand crafted from a dog turd. and the little end of the rod is the wrong size. and yes its the sunny crank available from scooter restorations at £45 and a j125 mazzercheezy rod is also available from s.r. so with the small mod and rod swap you should be able to have a complete starstream crank for less than £140. and if you are swapping the rod you could then get a better quality one. i will put some pics up and show the difference between the sunny crank and the starstream crank . whilst im on, the sunny cylinder 100cc has better port lay out than the cento and the sunny piston has thin wire rings . so another option for lui/vega/cometa and j rangers for a cheep upgrade. back to the crank the mod coulb be done without splitting but because i will be spliting my crank i will carry out the mod then. Cool
Re: will it work ?
Post  littlemoon on Wed Feb 06, 2013 2:01 pm
NIGE wrote:just got over the flu not had a look on site for weeks.wow simon .this might be of some help .the starstream i have seen with this kit on.the reed valve is pointing the other way .to the frame not the wheel. it will work and you will have the fastest luna in the world using a j range engine brilliant stuff simon.i will still race ya Twisted Evil Razz
i have thought about that but thought it would not work, would be a lot easier and even more ridiculous, i like it Shocked Cool . ... will ask someone with a brain if would work, good job i aint welded the packer on yet.
Re: will it work ?
Post  littlemoon on Fri Feb 08, 2013 3:44 am
wont need to rotate the top end as i have had the motor set up with a wheel in place, just needed to slice a bit off the inlet manifold. even if i rotated the cylinder i would then have to get the exhaust in, which would be harder to do but not imposible. here are some pics
crank difference
clearence
Ouch
Post  Admin on Fri Feb 08, 2013 9:20 am
That tyre is very close - in fact too close (IMHO). Given that when a tyre is warm it can expand by up to 5 mil then its an issue that will need looking at.
Re: will it work ?
Post  NIGE on Fri Feb 08, 2013 11:35 am
thats a bit close.can you use another type of manifold or shorten the one you have .because tyres do expand.you have got to get this to work now simon Twisted Evil
clearence
Post  littlemoon on Fri Feb 08, 2013 2:01 pm
packer
Post  littlemoon on Wed Feb 27, 2013 2:14 pm
here is a pic or 2 of the packer
pic hosting
upload pics
free photo hosting
rod and eccentric pin
Post  littlemoon on Wed Feb 27, 2013 2:37 pm
drt 105mm rod and drt 2mm eccentric pin
free photo hosting
rod has a 12mm wide big end and the pin is 20mm diameter so will need to grind the ends that go into the webs down to 18mm. the usuall upgrade for the vespa small frame kit is to go 51mm stroke and 105mm rod, so with the 2mm + or - eccentric pin i can get the starstream crank from 48mm to 50mm stroke , gets me right in the ballpark the drt vespa parts are very good quality bought via wayne at www.wolfeperformance.co.uk as he gets a dealer discount via sip . ignition wise i think i will bight the bullet and buy a lunatronic kit. staytuned folks . simon
gearbox upgrade
Post  littlemoon on Wed Feb 27, 2013 2:48 pm
gearbox, i have a complete starstream and vega drive trains that i will be getting a special process/coating aplied. used by a certain f1 team based in woking, they are on the same industrial site where i work . they have done gearbox parts for a big le mans team as they were having trouble with gearbox failures, after treatment no more failures. the f1 team has gearbox and engine parts done. they have done pistions and heads ect , this job for me will be f.o.c Cool
Re: will it work ?
Post  daz.h on Wed Feb 27, 2013 2:54 pm
f.o.c is always a good price Smile
some quality work there simon, a well earned pat on the back for you . Exclamation
Re: will it work ?
Post  Thackers on Thu Feb 28, 2013 10:47 am
I think i've said it before Simon, but it's worth repeating. You are a very clever lad, my hat is raised sir cheers
Re: will it work ?
Post  madmaex08 on Wed Feb 17, 2016 8:08 am
did you ever get the engine running with the Parmakit and the sunny crank? I still did´nt quite get what mod, beside changing the rod, you need to apply to the sunny crank to make it work in a Starstream setup.
madmaex08
Re: will it work ?
Post  timthemod on Fri Feb 19, 2016 5:33 am
I'd just be interested in doing a cylinder upgrade to 100cc (from 75) using the Sunny barrel and piston. Would this would using the modified crank, would any other internal mods be required?
timthemod
Re: will it work ?
