Vega suspension questions
As I said in a previous post, I am preparing a Vega 135 to do Lammie Drive 2 next year - Australia - Top to Bottom.
Reading about the state of some of the roads I am likely to encounter, I am concerned about the strength of the suspension (front and rear), and the ability to handle miles on end of 'washboard' tracks when carrying what kind friends have referred to as a 'fat bastard'.
Anyone have any thoughts, however radical? (No, I'm not going to cut a leg off or have liposuction!) Any way of increasing the suspension travel (which might also give more ground clearance - a good thing!)
Someone suggested marrying the lower loop of an Li fork with the stem of a Vega fork, but I am concerned that might add a lot of weight. Or just fall to pieces, if I do the welding!
On a completely different tack, anyone know of a custom fuel tank fabricator (aluminium or steel?) they could recommend?
Thanks in advance for any help!
tonyicon- Posts : 28
Re: Vega suspension questions
I have seen the welding of series 3 fork loop done a couple of times, that Vega that had the ts1 engine fitted for example. Dont think weight would be such an issue for that scooter though...
Its quite easy to fit extra dampers to the front forks, that might help..there's some parts on UK ebay at the mo
http://www.ebay.co.uk/itm/LAMBRETTA-VEGA-COMETA-LUI-FORK-DAMPER-MOUNTS-FOR-SUSPENSION-UPGRADE-/261094531346?pt=UK_Motorcycle_Parts&hash=item3cca726112#ht_642wt_1186
also you could upgrade the rear shock, again there's one on ebay at the mo..dont know how good that would be
http://www.ebay.co.uk/itm/lambretta-lui-vega-luna-range-custom-race-rear-shock-/251148178538?pt=UK_Motorcycle_Parts&hash=item3a7999146a#ht_509wt_1186
personalty I think your bloody mad trying
» Front Suspension & Hub Questions
» You reed valve conv guys
» front suspension
» vega 75s sh 1/18?
» hub/wheel/tyre/brake/suspension upgrade...!
» front suspension
» vega 75s sh 1/18?
