starstream 125engine
hi, can anyone tell me if a starstream 125 engine will go straight in a lui 50 frame,and what modifications are required, ie rear shock etc.i am new to the luna range and need al lthe help i can get,stupid comes easy to me.
cheers frank.
cheers frank.
it is possible but does not go straight in
if memory serves you have to make bigger holes in the frame and make a spacer yourself for engine mounts and fabricate a single sprung/damper mount at the rear of the crankcase instead of the 2 piece set-up, there are a few ways I've seen this done - hope this gives you some idea what's involved.
littlewilly- Posts : 59
Re: starstream 125engine
littlemoon is currently doing this, might be wise to drop him a private message and pick his brains.
and dont forget to fit the j front hub to keep the wheels inline
littlemoon- Posts : 162
» pin for a starstream crank
» Starsteam Gearbox
» Wanted....Starstream/J125 1st Gear Cog
» Starstream j125 cranks
» starstream in to vega bearings.
» Starsteam Gearbox
