Leg burner pipe
Leg burner pipe
I have a chisel speed remade one that I don't need. Never used open to sensible offers.
Re: Leg burner pipe
Drop me a PM, rough idea of what you want?
Adam Sleight- Posts : 134
Re: Leg burner pipe
You know they won't fit a lui?
Re: Leg burner pipe
This is it in case you are wondering what I am on about
http://www.chiselspeed.co.uk/lambretta-vega-chiselspeed-ads-exhaust-121024-p.asp
Re: Leg burner pipe
I'm putting the Parma 80 kit on it if that helps? Or is it the actual mount that wont work?
Re: Leg burner pipe
I have no idea about whether this would be a suitable pipe for a Parma kit. Maybe someone else has tried this? Or you could ask Chiselspeed although that's a bit cheeky as you are not actually thinking of buying one of theirs directly!
As for the mounting bracket - it comes with a bracket to fit it to a Vega. Now my Lui did not have extra part on the engine casing for this and I had some alloy weld added so I could fit my normal Vega pipe. I also believe that people have created other ways of supporting the leg burner pipes that don't use the original Vega mounting points
Re: Leg burner pipe
To be honest I cant make up mind as to whether to sell or not! I have two good pipes and only one scooter so I cant use them both! The thing is I'm tempted to hold on to it until after I have run it in (only another 780 miles to go!) and see if it offers enough of an improvement in performance to warrant keeping it and selling my std pipe instead.
However its probably going to take me a few years to run it in and I could do with the money. Also it would need either chroming or coating before use which is another issue for me before I can test it.
I guess I need to think hard about how much I need the money!
legburner
decisions, decisions.
i was in the same boat deciding wether to do a 135 or tune the 75 barrell.
boozee- Posts : 63
