LUNA OWNERS CLUB
Would you like to react to this message? Create an account in a few clicks or log in to continue.
Front sprocket bolt
Front sprocket bolt Empty Front sprocket bolt
Post  Thackers Tue Mar 16, 2021 9:01 am
So, having recently switched to a new 12t front sprocket that of course doesn't have the cush drive, and seeing said bolt unwind itself whilst on the stand ticking over has anyone Any suggestions to prevent a disaster?
Yes there's thread lock to consider but is there a better way?
I can't understand why rimini would allow such a flakey method when in conjunction with their 135cc kit!! Why don't they produce a cush drive sprocket with less than 13 teeth?
Cheers.
Front sprocket bolt Empty Re: Front sprocket bolt
Post  storkfoot Tue Mar 16, 2021 9:49 pm
I applied loctite when I built mine, especially as it is not under tension like with a Cush drive. But, have you checked the threads on your bolt and crank?
Post  Thackers Wed Mar 17, 2021 6:55 pm
Hi, thanks for the reply. The cush drive bolt is in a1 condition on the threads so i can only presume the crank thread is the same. The bolt i tried was a m7 kickstart bolt without any threadlock. I've bought what i hope is the correct bolt along with the washers, so this ill try with threadlock . I have tested the threadlock solution i have and it works well so i'll be sure to clean all surfaces before i apply it.
I'd just feel more confident with a cush system. Perhaps this final throw of the dice on the 5 speed will work, if not it's out and the 4 speed back in along with the sprocket and the cush drive. Fingers crossed
Post  storkfoot Thu Mar 18, 2021 7:28 am
Have you checked that the bolt isn’t bottoming out in the crank?
Post  Thackers Thu Mar 18, 2021 9:35 pm
Yes i used the probe on my digital vernier to check its depth and it's clear. I'll be sure to check when the bolt i'm waiting on arrives for the same thing. Thanks
