STEERING LOCK..
STEERING LOCK..
Hi... was looking at trying to get the steering lock number so I could get some keys cut..undid top nuts and bottom screws on the central tunnel but it still wasn't for coming away, didn't want to get a screwdriver in there and start bending things..Am I missing something ???.....
885donald- Posts : 19
Re: STEERING LOCK..
Hi. You’ll need to release the headset top and then the headset bolt. At that point, you should be able to pull the headset up enough to allow you to take the tunnel out.
It isn’t easy though
885donald likes this post
Re: STEERING LOCK..
Cheers... I'll give it a go this weekend and see how long my patience will last.....
Re: STEERING LOCK..
can be a pig of a job, trying to do it all at once, i screwed a hook into the garage ceiling and with a bungee, attached it to the handlebars in order to lift the bars clear enough while i pulled the tunnel back.
» steering lock removal
» wanted steering lock key
» Vega clamp on steering lock
» Wanted; Clamp on Steering Lock
» steering bearings,cables.
