LUNA OWNERS CLUB
Would you like to react to this message? Create an account in a few clicks or log in to continue.
Starstream rear brake arm
Starstream rear brake arm Empty Starstream rear brake arm
Post  Thackers Tue Dec 28, 2010 9:49 am
I'm still looking for the rear brake arm from a J starstream to up date my Vega standard one, thank you
Starstream rear brake arm Empty Re: Starstream rear brake arm
Post  Thackers Thu Oct 10, 2013 8:27 am
Still looking for this item as the part I recently bought turned out to be wrong Embarassed
Post  gc Thu Oct 10, 2013 9:31 am
Some on e-bay, Indian but better than waiting for ever for one to turn up.
Post  Thackers Thu Oct 10, 2013 1:48 pm
Thanks for the heads up. I'll have another look on Ebay I must have missed them Embarassed clown Sleep
Starstream rear brake arm Empty brake arm
Post  itsjoeyfontane Thu Oct 10, 2013 4:23 pm
...if you're fitting j hubs to vega case then I think the cams are different... in length?
i fitted j hubs...'Wack' modified a vega cam by beefing up the cam end for me...?
Post  gc Fri Oct 25, 2013 7:31 am
Did you order a brake arm Thackers? I know you've wanted one for a while so wondered if you'd seized the opportunity.
Post  Thackers Fri Oct 25, 2013 11:43 am
Hi mate, yes I finally ordered one off Ebay (from India) and i'm waiting on it's arrival. There was a bit of a delay in ordering as I rang Scooter Surgery following a tip off on another forum that showed them having one on their on-line shop. Useless really, their site is at least 3 years old and they didn't know if it was still in a box of bits:roll: I'm still waiting for a call back (nearly 3 weeks) Mad bounce Sleep I'll post up when it arrives from India on quality, fit etc.
Post  wack 63 Fri Oct 25, 2013 4:50 pm
Does it work Joey?scratch
Post  Thackers Sat Oct 26, 2013 4:07 am
Thackers wrote:Hi mate, yes I finally ordered one off Ebay (from India) and i'm waiting on it's arrival. There was a bit of a delay in ordering as I rang Scooter Surgery following a tip off on another forum that showed them having one on their on-line shop. Useless really, their site is at least 3 years old and they didn't know if it was still in a box of bits:roll: I'm still waiting for a call back (nearly 3 weeks) Mad bounce Sleep I'll post up when it arrives from India on quality, fit etc.
The item arrived today and is total garbage surprise, surprise . The two sides are completely different where the adjuster will fit and bent too, I think if I try to fettle it, it's going to snap plus the splines look to me like they will slip on the brake cam.
My search for this little item continues Sad
Post  gc Sat Oct 26, 2013 5:11 am
Worth a try-better than just hoping one turns up I suppose. They do make a massive difference to adjustment and when I can be bothered, will weld a couple of clutch arms together and adapt so I can adjust the clutch easily. Good luck with your hunt - be worth it when you get one.
Post  itsjoeyfontane Sun Oct 27, 2013 12:08 pm
wack 63 wrote:Does it work Joey?scratch
works a treat! stops dead... thank you very much! now up grading with sunny hubs...
Post  itsjoeyfontane Sun Oct 27, 2013 12:29 pm
...here's my thread from lcgb forum...
Starstream rear brake arm Small_762-1258054781
Starstream rear brake arm Small_762-1258054722
Starstream rear brake arm Small_762-1258054837
