Brake light switch
Brake light switch
Does anyone stock these, I've repaired mine several times but now it is just crumbling away, or is there an alternative available
shand- Posts : 64
Re: Brake light switch
I've looked all over, rimini and the German shops, nobody seems to have one. I'll look for one to adapt
shand- Posts : 64
Series three ones are the same. The only real difference is the riveted on braket. If you have the old one you can make a series 3 fit . The connectors are slightly different but not rocket science to modify.
Looked at that, looked like too much faffing about, so another repair, a bit of brass and solder and a fair bit of araldite and its back up and running. Thanks for your replies
shand- Posts : 64
You could always fit a vespa cable one to the front brake if you fancy modifying your electrics....
» Wanted..Vega parts
» Lui Brake light switch help!
» Rear brake switch alternative
» parts for light switch
» Vega/Cometa light switch
