vega to j range speedo cable.
hi, does anyone know if the standard vega speedo cable will work when using j/sunny front hub. cheers.
boozee- Posts : 63
Re: vega to j range speedo cable.
The depends on whether you are planning on using the Vega speedo drive on your hub? I guess that the J range had a different speedo drive method?
If yours is tbe thin drive I would think not. If it is the thicker type then yes with a bit of tbought.
gc- Posts : 92
speedo
using the j range speedo drive. ill have to compare them and see if vega cable can be modified. nothings ever simple is it.thats why we love them.
boozee- Posts : 63
Hi Boozee, I'm happy to be corrected, but even if a Vega one would fit the drive, wouldn't it be too short as they are fitted like a reverse pull cable? I may be wrong but I'm pretty sure you'll need to use a J range cable
