Air Filters
Page 1 of 2 1, 2  Next
Air Filters Empty Air Filters
Post  Snails on Mon Jan 19, 2015 4:32 am
Anyone running a K&N air filter or similar and can supply a link of where to purchase from. I was running one but it fell off and is now lost in space. Looking at the K&N site they dont seem to have any options for 25mm carb size (which is the outer size of my SH1/20 carb mouth)
Air Filters Empty Re: Air Filters
Post  Scooter Paul on Sat Jan 24, 2015 2:10 am
MB sells foam filters that size. You may want to consider one with an elbow to give more clearance away from the kickstart. Or go onto the Dellorto UK site they have all sorts of air filters.
Post  Snails on Sat Jan 24, 2015 5:18 am
Thanks Paul. Defo want a kinked one as the last one was defo annoying me when kicking over which also might of led to its eventual demise
Post  Snails on Wed Jan 28, 2015 9:32 am
Paul - I cant see them anywhere on the MB site. I don't suppose you can provide a link?
Post  Scooter Paul on Wed Jan 28, 2015 9:50 am
Ed, MRB0416K is what I had in mind.
Post  Snails on Thu Jan 29, 2015 3:41 am
Thanks Paul. Would need to check if would fit a 20mm
Post  Scooter Paul on Thu Jan 29, 2015 3:44 am
They say it does. BIM that the Vega carb has no lip to locate the air hose securely hence their propensity to let air filters fall off. Don't ask me how I know!
Post  Snails on Thu Jan 29, 2015 4:38 am
Oh dear. Sounds painful
Post  timthemod on Thu Jan 29, 2015 7:19 am
timthemod
Post  Snails on Thu Jan 29, 2015 8:10 am
Just the filter part Tim?
Post  timthemod on Thu Jan 29, 2015 8:55 am
no carb as well if I can get it to fit? Impossible to get a replacement 20mm and i think my carb is a bit shagged.
timthemod
Post  daz.h on Thu Jan 29, 2015 9:32 am
tim, theres plenty of 20mm carbs around, granted they are all used, not many true vega 20mm carbs, but you can easily fit a screw in pull up choke plunger to another carb, rather than have the vega flip choke.
Post  timthemod on Thu Jan 29, 2015 10:04 am
i know there are 20mm carbs around, but not Vega ones. i think there are some differences between Li/GP 125 carbs and Vega carbs. Just looking for something new and also where the filter won't fall off.
timthemod
Post  trotsky on Thu Jan 29, 2015 1:21 pm
Hi Tim, if your looking for something different, we have used the Polini Cp 21mm Carb on a 125 Conversion with good success. Chiselspeed sell these, the filter & do the manifold conversion also (Buy new, or supply a 150 manifold). I'm sure he could do something if yours is a 75cc? Hope this helps....Steve
Air Filters 100_1626
Air Filters 100_1627
Post  Snails on Thu Jan 29, 2015 2:24 pm
Trosky - How much did the carb set you back roughly?
Are you saying a 150 manifold is all you need for the conversion?
Would you say the carb offers better performance than a sh1/20 for a 125?
Tim - I have a spare Vega sh1/20 needs a bit of an overhall. I was waiting for someone to confirm whether they wanted it but if they don't it will be up for sale soon.
Post  trotsky on Thu Jan 29, 2015 3:25 pm
Hi Snails, I think the Carb itself cost about £80. The guy I built the Vega for took it back to Chiselspeed to have the engine dynoed & carb dialled in. Gave about 5.5 BHP & about 5 in torque I think? Standard J 125, exhaust & electronic ign. Steve says it starts,rides & pulls smoothly. To date there have been no probs with Carb & is not harsh on fuel consumption. Hard for me to say if it's better or worse than SH20 as I haven't used that combo, we needed a carb for it so tried the Polini. It seems a good alternative if you can't find original items.
Yes the kickstart sits close to the filter with a Vega Kickstart but Steve has used a J one for his own preference. Personally I like the Vega kickstart (you could just move the kickstart down a spline). So long as you're aware of it when starting, then there shouldn't be any issues. We had a 125 barrel & all that was needed was the manifold machined to match rubber mount I think? A longer Throttle cable maybe needed also.....Steve
Post  timthemod on Fri Jan 30, 2015 10:37 am
Thanks Trotsky, those Polini carbs in a few different sizes. did you not have to seal the vaccum tube on the carb? Found a 19mm on ebay brand new £54, will still need to get the manifold and the rubber mount, and probably use the primavera type filter, as it won't fall off.
http://www.ebay.co.uk/itm/CARBURATOR-POLINI-CP-CHOKE-KNOB-19-D-/161491511373?pt=UK_Motorcycle_Parts&hash=item2599a4e84d
Snails thanks for the offer, and I may come back to you. I just want to start with something new, rather than a 30 year old carb.
timthemod
Post  trotsky on Fri Jan 30, 2015 2:32 pm
Hi Tim, the carb came with black rubber bungs that go over the tubes - was as simple as that. I'm sure we got the rubber mount from Chissys as well? Worth giving Martin a call, he'll see you right....Steve
Air Filters Empty polini carb
Post  boozee on Sat Jan 31, 2015 1:33 am
hi, chiselspeed just supplied me with one of these carbs fitted to a atomic reed valve.using it on a tzr conversion.nice and compact little carb. only issue i had was clearance on cable adjuster.also the manifold inlet was offset from the port on barrell.sorted these minor details out by making a packing plate and shaping it to match them up.
Post  Snails on Sun Feb 01, 2015 3:11 am
Ah. Found my link for the air filter that I had fitted
http://www.hilevel1.co.uk/hilevel/index.php?main_page=product_info&products_id=6691
I could buy another but as I could never get it to run properly with it on and also as it fell off I have my doubts as whether that is such a good idea. Although there is probably nothing to say that the bad running was necessarily the air filters help. I wonder if there is much variance between what one air filter lets in an another?
Post  daz.h on Fri Feb 27, 2015 4:00 pm
while having a bit of a rake around in my shed, looking for something else completely, I came across an old K&N Filter that I used on my first ever Vega I built (before the air boxes had been remade)
here is the part number.
Air Filters 00510
Post  daz.h on Fri Feb 27, 2015 4:03 pm
side view of the filter, its seen better days, but you get the rough size.
worked well though.
Air Filters 00710
Post  Snails on Wed Mar 04, 2015 3:12 am
Thanks Daz, Cant seem to find one with that part number - or at least a way of identifying which it is and the K&N site does not allow a search by part number. Also they dont see to start any with an F - anymore at least
Post  daz.h on Thu Mar 05, 2015 3:44 pm
it never originally came off an engine, it was fitted to a water tank as a breather, at a place where I worked, and I acquiredit Laughing
Post  Snails on Fri Mar 06, 2015 5:39 am
ha ha - oh well, dont suppose you can go back and see if they have any more Wink
