Latest Project
+13
lunaloon
lammievega
Weeks
17 posters
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: Latest Project
storkfoot wrote:For the sake of paying Beedspeed £22, making my own looks like hard work, Ed. But thanks all for the heads up. Google reveals:
http://beedspeed.com/manuals/Varitronic%20Vega.pdf?osCsid=ekn5c1vpc4cgraeigeobjmp4d1
Ha ha that's what I thought!
Re: Latest Project
Well it's been a couple of weeks with some very late nights after work in the garage sorting the electrickery out. Routing & shortening the loom as it was too long, re-wiring the Digi-Speedo & all the gubbings, adding a simple ignition switch, cutting, soldering & joining it all (running & hiding everything inside the body), & then continually testing it, to make sure it all works . I've finally got to where I'm happy with it, to the point I can now start finishing the build. Now got everything back so can get cracked on...
Electric box..
Timing marks made..
Ignition Switch drilled & locked in place..
Motor finished & in, Rear Hub & Mudguard on now electrics are sorted..
Front end all tested, will tidy up & start cabling tomorrow...
Electric box..
Timing marks made..
Re: Latest Project
A work of art Steve -liking the ignition switch idea (a lot!)
gc- Posts : 92
Re: Latest Project
Your electrical work is the best I've seen. I too went with a simple ignition switch but put mine on the centre beam opposite the steering lock, making it more difficult to simply start and ride away can only be a good thing.
vega
Super work Steve the electrics box is a great idea and very tidy.
lunaloon- Posts : 78
Re: Latest Project
looking better every time i see it,not just the looks but the engineering side of it too
li mick- Posts : 100
Re: Latest Project
yes, as the others say, great work, a great example for others to follow on from , well done.
project
more please to satisfy your luna public
Re: Latest Project
Hi fellas, thanks all. Gaz & Thackers, yes a simple switch should help & having the coil hidden away will help over-ride simply by-passing the switch. Not that exciting, but here are some more Pix of my progress so far...
Wiring & cabling from headset finally taking shape...
Head-set starting to take shape...
Throttle routed & connected...
Clutch & Gear cable outers cut & routed...
Re: Latest Project
Cheers Daz.....It Runs at last Got plenty done today, just gotta dial the timing in, bolt on the final parts & deal with any issues that arise . The lights flicker at low revs now it's running & on AC, but I can live with that (was spoilt while testing everything via battery!). Will probably switch the horn & brake light over onto the DC feed to help them out...
Had to add a Capacitor as the Speedo wouldn't work direct from the rectifier, 9V battery supply for the Speedo Clock will be velcroed to the lid..
Back-end..
Front-end..
Headset finished, just got to decide on grips..
Back-end..
Front-end..
Re: Latest Project
Great work, I'm really impressed. I do hope you put the seat on before going for that ride though
latest project
looking good, coming together nicely.
did you use a spacer between reed block and cylinder. matched mine up and the ports are way out of line with each other, so made a spacer profiled to match them up, hoping this will work.
boozee- Posts : 63
Re: Latest Project
very neat wiring, nice to see a bigger anorak than me for a change
Re: Latest Project
Cheers snails, yes this week hopefully - with seat .
Cheers Daz, I'm all wired out now that's for sure . Your work looks fine to me mate..
Boozee, not sure what reed-valve your using but I've got a mini atomic on mine. I just matched the reed-block direct to the inlet as there is plenty of meat on the atomic, & then had a spacer made so the Carb would clear the crankcase (TS1 Exhaust Gasket is a perfect template). My Barrel has a 6mm packer underneath as well which conveniently helps with the cable routing to the gear block.
Hope the pix help...
l
l
reed valve
hi, ive got the mini atomic as well with a polini carb. i opted out of porting the reed valve manifold (got scared.) but seems like the better option. job for the weekend i think. havent needed to space the carb out as the polini carb is a lot smaller, just about get cables around it.
boozee- Posts : 63
headcowling
great work Steve can i ask if you you are going to use a packer plate and use original headcowling or are you fitting a J125 one
cheers john
cheers john
Re: Latest Project
Thanks fellas, John, I'm using a J125 one, because i've taken the seam & "W" bracket out, i didn't have to put a Ding in the cowling. I've made 2 little spacer plates that go between the bottom of the cowling & on top of the casing where they meet to allow for the barrel packer.
Here are some pix of it (nearly) finished. The rack is at the powder-coaters so just got to adjust the cables & dial in the speedo with the wheel circumference to get the correct speedo reading....Oh & then put the dreaded Beam on ....MOT & then good to go..
Re: Latest Project
Exceptional attention to detail, Steve. Great engineering, functionality and looks quick (for a vega )
Re: Latest Project
That is absolutely stunning, the centre beam, its right up there as one of those hide the hammer moments
shand- Posts : 64
Re: Latest Project
I've got to agree, that is exceptionally good! Well done that man!
sticker
well done that man top work love the Lunatronic sticker
Page 3 of 4
