Kickstarter
Kickstarter
It's never occurred to me before to be a problem but recently I was advised by a reliable source that you shouldn't remove the kick start pedal without taking off the chain case as it needs resetting afterwards. Any other views?
Re: Kickstarter
I'm pretty sure I've had mine off with the chain case side still on the casing.
Re: Kickstarter
had mine off numerous times too without the casing coming off. what is there to reset? the stud in the kick-start piston runs up and down the buffer, of which can be slightly adjusted but that's about it.
I have known the kickstart piston to become dirty and clogged and as such not withdraw completely and thus leaving the teeth slightly exposed to catch on 1st gear
Re: Kickstarter
I've heard that before Paul, possibly from the same person as you. Cant remember the reason given exactly but it was something that led to the piston catching on the first gear teeth but for a different reason than what Daz says.
I'm glad you have brought this up as I recently removed my kick start pedal as its off to Hull for a rechrome and I was wondering whether i'd need to lift the case cover when I refitted.
At least there is no need to take the exhaust off like on a series 3. Pain in the bum that, just to get to the gears
Re: Kickstarter
Thanks all. Finally got into the workshop today after a month of house improvements- nightmare! I've checked out a side case already off a bike and, yes, there's no need to reset anything. The pedal can be taken off with the side case in situ.
