le vega de ma moitié
Post  panamesc on Fri Oct 01, 2010 5:36 am
or my wife véga Wink
birthday present , 4 years ago , not yet in running order Embarassed
i have worked on it , it's now complete , but still non running Laughing
panamesc
Re: le vega de ma moitié
Post  daz.h on Fri Oct 01, 2010 7:29 am
got a spark? fuel getting through?
Post  panamesc on Fri Oct 01, 2010 7:44 am
new points and condenser (thanks mr booth)
new old stock ht coil
it starts but don't want to stay at the iddle or revs very high ....
no air leaks , spi seems ok ....
it's worst with the choke ...
i will try with another carb
panamesc
Post  daz.h on Fri Oct 01, 2010 9:37 am
give carb a good clean, make sure the jets are not blocked.
attomiser should be 5899-6 main jet around 68
Post  panamesc on Fri Oct 01, 2010 11:08 pm
carb is clean , parts n° and jet size are the good ones
i have 2 spare sx200 carbs , so i think that i will put the the vega interior in
but i'm not really sure for the timing
i know how to do it Wink , but the mag housing is broken and i can't mark it ....
so maybe i'm wrong ?
a good picture with some mesurement of a working stator ?? Laughing
panamesc
Post  daz.h on Wed Oct 13, 2010 3:05 am
have you got it running yet panamesc?
i use the bulb and battery method to time mine in, i also use a digital micrometer to gauge tdc.
from memory the firing point is around 1.8mm before tdc.
Post  digger59 on Wed Oct 13, 2010 10:16 am
If the pilot jet is blocked or there is an internal blockage in the carb it will suffer and most Vegas were a little fluffy on tickover try a slightly bigger pilot Jet original is 45 so maybe try a 48.I assume it's 75cc and not 125 conversion,if it is that's maybe why it's suffering.
Another thing that makes them run shite is bigger exhaust ,but loking at the pics it seems standard ,the insides haven't been cut out,have they?
Check also that the woodruff key is not sheared on crank/flywheel it could be stuck in the wrong position.
Hope this helps I assume you are in France looking at the number plates.
digger59
Post  panamesc on Tue Jan 25, 2011 2:45 am
hoops
away from home for 3 mounths , haven't seen the replies ...
no work on the vega since
i have a lot of px electronic stator and a AF electronic rotor , maybe i will try this way ...
panamesc
