Piston possibly suitable for Vega
I'm always loking at pistons which could be used in the Vega here in Colombia,one comes to mind as looking suitable it's from a Bajaj Sunny 80cc (Yes ,Bajaj who make the Chetak Vespa clone) it's like a Honda 50 cub but 3 speed ,2 stroke).
digger59- Posts : 17
Re: Piston possibly suitable for Vega
there must be something available off the shelf that will fit, its just finding it
going to use a malossi piston in my vega, from memory its around 51mm, just needs a small packer under the cylinder.
i'm sure somewhere on the internet will be a system where you can input the piston size, crown height etc and it will give you a reccomended piston.
something similar to whats advertised below.
http://cgi.ebay.co.uk/Quad-Bike-52mm-90cc-2-Stroke-PISTON-KIT-Kazuma-Panda-/160471366613?pt=UK_CartsParts_Vehicles_ATVQuad_Trike_Parts_Accessories_SM&hash=item255cd6bbd5
Vespa 90 rings fit with a little gapping to the Vega piston.
file
you have to file the gaps in the rings back a bit to clear the ring pegs. i am using a set of vespa rings in my lui 75cc
littlemoon- Posts : 162
I'm not convinced by a 4 stroke piston in a 2 stroke, you certainly wouldn't get far with the oil control rings fitted.
that piston casting looks worse than th rocker covers I have made!
i was refering to the diagram and the size measurement table, not the actual piston.zefarelly wrote:I'm not convinced by a 4 stroke piston in a 2 stroke, you certainly wouldn't get far with the oil control rings fitted.
should have made myself a bit more clearer.
» Vega piston
» tzr piston side play
» j125 / tzr 150/ reed valve
» PISTON HELP
» Rod used for tzr piston??
» PISTON HELP
