gear box shim
gear box shim
Post  joeyfont on Sat Sep 04, 2010 10:57 am
hi bit of a long shot but i need a 2.2mm gear box endplate shim-the big one that sits in 1st gear....
mines jumpin out of 2nd- selecter and gears all seem fine but there is 25thou '' clearance on shim??!!
currently have 2mm
joeyfont
Guest
Re: gear box shim
Post  daz.h on Mon Sep 06, 2010 2:28 am
did you tighten the hub down first before measureing?
i will have a look and see what sizes i have, is the 2nd gear cog also the correct way round, i have made that mistake in the past, it resulted in been rarely able to select 2nd.
