Engine stutter and power loss
Engine stutter and power loss Empty Engine stutter and power loss
Post  dave_j50 on Thu Mar 21, 2013 1:11 am
Can somebody give me some advice for my lui 50cl. The problem i have is when the engine is reving high and approching top speed in each gear, it begins to stutter and looses power. I have serviced and cleaned the carb and the scooter idles very well, the scooter starts fine and runs very nicely.
If somebody could give me some ideas to try it would be appreciated.
Cheers David
dave_j50
dave_j50
Engine stutter and power loss Empty Re: Engine stutter and power loss
Post  Thackers on Thu Mar 21, 2013 11:27 am
Sounds electrical to me, unless your main jet is blocked. I'd try the easy bits first, new plug and cap plus H.T lead then going further onto the points and lastly your stator coil's and wiring from them . Welcome along too Very Happy
Engine stutter and power loss Empty STSTSSSTUTTA PPPROBLEM...
Post  itsjoeyfontane on Thu Mar 21, 2013 5:45 pm
...airfilter blocked,main jet/atomiser blocked,fuel tap/filters blocked,poorspark-fit champion n3/4 20 thou gap,ht cap wire,coil,point/condenser clean /re-gap/ change,poor flywheel magnetism,too much oil mix,crank seals,air leak,duff fuel,worn cylinder---if its not one of these then i dunno ?...old age...lambretta...oh what a joy !
..at idle does it die when you turn the lights on...?
Post  daz.h on Fri Mar 22, 2013 1:48 am
any backfire ?
could be points bounce, as others have stated, i'd go for easy options first, new plu, ht lead, plug cap, check coil earth.
Post  dave_j50 on Fri Mar 22, 2013 2:12 am
thanks for the suggestions........ seems i will have a busy weekend, i adjusted the points recently so this would be a good thing to double check first, i also used a different oil to mix in the fuel and it is smoking more than normal so maybe this is affecting things.
the engine continues to idle normally when i turn on the lights.
i put in a larger main jet aswell so maybe i should take this back to standard for now.
Cheers Dave
dave_j50
dave_j50
Post  dave_j50 on Fri Mar 22, 2013 2:29 am
daz.h wrote:any backfire ?
no there is no backfire, why would you get point bouce? is it because the points are too close or that they are worn out?
dave_j50
dave_j50
Post  Thackers on Fri Mar 22, 2013 5:22 am
I thought points bouncing was usually down to a tuned higher reving motor that needed a 12v electric conversion. I suppose the right timing is the common link between the 2
Post  Scooter Paul on Sun Mar 24, 2013 10:30 am
I've had a couple of scooters over the last few years that had symptoms similar to this. One had a slight leak at the head, the other worn rings. Both started and ran well up to a point then stuttered and coughed as if being starved of fuel. Lapped the head on one and fitted new rings to the other. Both ran well afterwards,
Post  dave_j50 on Wed Apr 17, 2013 3:25 am
i reduced the size of the main jet as i found a puddle of fuel inside my carb. this has resolved the problem. It look like the carb was flooding.
Thanks for all your advice.
ps. i do get a small amount of backfire when changing down.
dave_j50
dave_j50
