You reed valve conv guys
Page 2 of 2 Previous  1, 2
Re: You reed valve conv guys
Post  Thackers on Mon Apr 08, 2013 10:47 am
How i got over the carb finishing close to the chaincase side was get from the scrapyard a length of radiator hose that had a kink or slight curve in it. My Dellorto is the 25mm rubber mounted type. The kink moved the carb away from the trouble areas. I might use the same piece when i finally get my reed block fitted Embarassed
Vega 140 carb and reed block
Post  tonyicon on Sat Apr 20, 2013 8:09 am
I have spent some more time futzing with the carb fitting, no elegant solution has occurred to me yet. I got a ScootRS Atomic reed block to try and although it relocates the carb a little, still not enough to fix the problem. The Atomic reed block itself needs fettling to fit the StarStream barrel, but not much. My impression is that it is a better quality job than the LTH unit.
Trotsky's installation with the Dell'Orto is much neater.
Here are a few pics of what I'm on about.
Also the rubber mounting flange for the 26mm Mikuni is not a terribly good fit (no annular ridge to mate with the bump on the carb stub) I fear it may 'wiggle off' all too easily in use.
Any thoughts etc would be welcome!
tonyicon
Carb Fettling
Post  trotsky on Sat Apr 20, 2013 2:00 pm
Hi Tony, did you get the Mini Atomic? Very little fettling is needed on my Starstrem Barrel. I've started my Dry build & below are some Pix of the Carb set-up, hope these help. I trimmed the Cowling & mudguard to fit & we had a spacer made to clear the carb from the crank-case (may be able to get some made if any-one wants one). As you can see the Carb misses the Kick-start by a good margin so there'll be no issues with a Filter.
I stole your idea & got a Sunny rear hub as well Embarassed & i'm gonna use a Zip type front wheel so i'll hopefully be Tubeless all the way cheers The pix aren't that good on here. so if you PM me your e-mail addy, i'll send some over that you can enlarge to get a good look at. Will post more as i go....Cheers Steve
Post  itsjoeyfontane on Sat Apr 20, 2013 2:57 pm
...lookin good guys.. the kick start lever is an easy modification....ive already modified one ready for my next project... after doing the Beamish Trial and it jabbin my ankle too many times....
its easy to apply a bit of heat and bend it a little... Very Happy
Post  itsjoeyfontane on Sat Apr 20, 2013 3:24 pm
...not got a reed block yet..but I was going to try and make a manifold adapter that would angle the carb up and towards the rear...or am i livin the dream..? Evil or Very Mad
Kickstart
Post  tonyicon on Sun Apr 21, 2013 10:24 am
Hi Joey
Can we see a pic of your modified k/s lever? I was considering trying to make a folding lever as used on many vintage motorcycles, but I am not sure that would work within the space available
tonyicon
Cable Routing
Post  trotsky on Sun Apr 21, 2013 1:31 pm
Here are some Pix of my cable routing with the Atomic Reed Block. I do have a 6mm barrel packer, so i have a little more space for routing. Tonyicon cleverly used a Carb elbow to get around the tight Reedblock/Gearblock space....Cheers Steve
