Horn access ?
Horn access ?
Post  willie1505 on Sun Dec 30, 2012 6:02 am
Hi all, my horn doe's not work even though she passed MOT like this.
To gain access I have removed cover/frame screws however panel seems fixed solid.
How will it remove or am I missing the point or screws or whatever ?
Alun.
willie1505
View user profile http://alunwilliams1505@ntlworld.com
Re: Horn access ?
Post  littlemoon on Sun Dec 30, 2012 3:30 pm
two screww at the bottom (engine end) and two at the top just below the headset . you will also need to lift the head set off a bit to aid removing (allen head pinch bolt on the right hand side of headset) and re fitting the frame cover. stick the rubbers on the frame cover with some dabs of black sealer and leave to set before refitting the cover and a spray of soapy water on the leg sheilds aswell to aid fitting, can be a prat of a job to do. cheers simon ... ps forgot to add you will have to leaver off around the steering lock aswell
Re: Horn access ?
Post  daz.h on Sun Dec 30, 2012 4:03 pm
another tip is to tell the kids to go out and play, that way they wont pick up any swear words that you will be coming out with Very Happy
Re: Horn access ?
Post  daz.h on Sun Dec 30, 2012 4:05 pm
i have repaired the horns in the past, its usually a wire inside has snapped off due to the vibration of these things,
drill out the rivets that holds the front plate on and have a look inside.
Post  willie1505 on Mon Dec 31, 2012 1:14 am
Thanks lads, will try later. Its just that I am frightened to scratch the paintwork (its mint).
Daz thanks but do already have new 12v horn that I intend to fit.
Alun.
willie1505
Re: Horn access ?
Post  daz.h on Mon Dec 31, 2012 6:18 am
have fun fitting it alun, the vega horns are chamfered at the rear.
Re: Horn access ?
Post  willie1505 on Mon Dec 31, 2012 6:38 am
Oh right Daz, will have a look at repairing it then. Ta again.
Alun.
willie1505
Re: Horn access ?
Post  daz.h on Mon Dec 31, 2012 10:51 am
willie1505 wrote:Oh right Daz, will have a look at repairing it then. Ta again.
Alun.
the 12v normal type horns can be fitted, but its a faff, in the pust i have cut two groves in the outer ring of the horm and clamped it up.
i do think some have used a small 12 volt buzzer in place of the horn.
i once went for an M.O.T test and although the horn was bearly working he told me he had to pass it as i was wearing an open faced helmet, therefore i can give the audiable warning !
Re: Horn access ?
Post  willie1505 on Mon Dec 31, 2012 12:42 pm
'i once went for an M.O.T test and although the horn was bearly working he told me he had to pass it as i was wearing an open faced helmet, therefore i can give the audiable warning'
That is crackers !!!!!!!!!!!!!!!
Will look at fixing horn once the rain stops !!!!!!!!!!!!!!!!!!!
Alun.
willie1505
Post  willie1505 on Tue Jan 01, 2013 6:34 am
Done it lads, thanks a lot. What a **** of a job, done minor damage to panel but will touch up easy.
Daz will drill rivets out and look for broke wire, all works with 12V buzzer wired in to check it was not wiring.
Thanks again.
Alun.
willie1505
Re: Horn access ?
