our Vega-in-bits
our Vega-in-bits
Post  ScootersO on Fri Dec 14, 2012 3:40 pm
now that our move is done, I was able to get our Vega out and take some pics. Ill add more as I get the engine and other pieces unboxed. I think im going to do a dry build on this scoot to make sure I have everything before I send it out for media blast and painting.
yes...I know I have my work cut out for me Smile
ScootersO
Re: our Vega-in-bits
Post  daz.h on Fri Dec 14, 2012 4:15 pm
cheers keep the pics coming Very Happy
Post  ScootersO on Fri Dec 14, 2012 4:28 pm
ill resize them next time as they are cut off a bit...
ScootersO
Post  ScootersO on Fri Dec 14, 2012 4:31 pm
ut oh, just found out the forks for this scoot, which were out getting a stripped and buggered up thread hole fixed are halfway across the country thanks to the US postal system...they were only 2 states away and have ended up 10 states in the other direction...fingers crossed we get them!
ScootersO
Post  ScootersO on Fri Dec 21, 2012 11:17 am
the fork turned up, so at least that isnt lost!
managed to get one table to dedicate for use for the Vega. I am thinking that I need to get this thing running as-is, then once running and everything working, I can strip it for a paintjob. Ive done a fair bit already, but I just need to know everything is here and its gonna work!
this is the frame and most of the parts. Ive put the stand on, and some bodywork loosely.
putting the stand on revealed a bent arm for the brake lever..
so i checked the brake pedal that came with the Vega and see that the pin for the lever is stuck in it. I didnt know that when I sent it out for powder coating...so now I need to see if I can get that out without damaging the powder coating too much. If not, Ill have to find a new pin, and use the replacement pedal.
the replacement hub I sourced is on the left, once I got the box o missing bits for this scooter, I sent out the original hub (on the right) for powder coating. its now all built and waiting for the forks to be built to be installed
engine media blasted and ready for cleaning then painting and building.
exhaust and some other powder coated original parts
polished levers and housings. trying to work out if I have all the parts for this. I dont seem to have the little tube that the throttle cable would go through, like a D one. are these made?
an assortment of springs that came in the box o bits.
think the 2 that are opposites of each other are some kind of rack spring?
box o bits to sort through. some Ser3 and LD items were mixed in, and some unknown things
I ordered a replacement column lock, but its the wrong kind. I have the original lock, I might see if I can get a local locksmith to cut a key for it. if not, are these strap on locks also made?
some new and more old parts
ScootersO
Post  Thackers on Fri Dec 21, 2012 11:54 am
Hi Gene, the long spring is either off the centre stand (return spring) or the brake pedal the others look like they might have come from a seat.
In all your boxes o bits have you got the throttle worm? It's small enough to easilly get lost. If memory serves it's oblong shaped and about a cm long with a raised ridge on the top set at a angle, this ridge sits inside the diagonal slot of the throttle tube, pictured with the gear change lever.
Post  ScootersO on Fri Dec 21, 2012 12:00 pm
I got a new throttle worm (and throttle tube) from Scootopia. Its an aluminum one, not brass. the parts book shows some other parts in that area Ill have to make a list and ask what they are, to see if I have them or not. I can see its gonna take some filing to get that whole mechanism to operate smoothly. I rode a Vega once that had been imported from the UK and the main thing I remember was how stiff the throttle was - you almost needed 2 hands to turn it! I wont let mine be that way Smile
thanks for info on the spring. ill get that put on. one of the springs looks like a ser 3 brake shoe spring...unsure of the others.
ill get more pics as I assemble things Smile and Im sure Ill have more questions
ScootersO
Post  Thackers on Fri Dec 21, 2012 12:04 pm
Do you have a parts book? If not i could scan pages from mine as you need them and P.M them to you if you want. Cool
Post  ScootersO on Fri Dec 21, 2012 12:17 pm
I do have one, thanks. a pdf I got from luna website before it went down. Managed to get a workshop book as well. thank you for the offer though Smile
ScootersO
Post  daz.h on Fri Dec 21, 2012 12:58 pm
the throttle tube / worm set up can be bad, my remade tobe was not perfectly round which i certainly dont think helped but after some bashing and a lot of swearing it was better.
i used a mixture of grease and grinding paste on the parts and connected up the carb, so there was resistance on the cable while in the tube, then it was just a case of turning the throttle what seemed thousands of times untill it all bed in together.
cleaned it all out and then just re-greased.
Post  daz.h on Fri Dec 21, 2012 12:59 pm
the strap on locks are not remade, only the bolt on ones, jem booth does keys for both types.
Post  ScootersO on Fri Dec 21, 2012 2:09 pm
daz.h wrote:the strap on locks are not remade, only the bolt on ones, jem booth does keys for both types.
there is no number on it, do I need to send the whole lock in to be done?
ScootersO
Post  daz.h on Fri Dec 21, 2012 4:53 pm
yes
Post  ScootersO on Sat Dec 22, 2012 11:05 am
do you have Jems email?
is he ok with shipping to/from the US?
ScootersO
Post  Thackers on Sat Dec 22, 2012 12:23 pm
Here you Gene,
jmb548t@yahoo.co.uk
Post  ScootersO on Sat Dec 22, 2012 12:28 pm
thanks!
ScootersO
jems email
Post  willie1505 on Sun Dec 23, 2012 2:44 am
Try this one.
jemsscooters@yahoo.co.uk
Alun.
willie1505
View user profile http://alunwilliams1505@ntlworld.com
