inlet mainfold for 25mm phbl
Post  E type on Sun Jan 22, 2012 8:50 am
i need to know which manifold you would use on a 130 tzr vega to mount a 25mm phbl carb ? any info would be appricated ......is it a 150 manifold modded ?..thanks paul
E type
Re: inlet mainfold for 25mm phbl
Post  NIGE on Sun Jan 22, 2012 10:09 am
hi i am using mb small block it will fit but it will be ofset to ports .i have matched the one side but there is a step on the other side plus step on top and bottom.when barrel is ported i will see what matching is reqhired.if manifold is still a bit big for ports i will build it up with ally weld and reshape to fit.pain of a job but will be spot on
Post  E type on Mon Jan 23, 2012 9:26 am
thanks nige gona try a 150 manifold i think but if any one else knows a better way i am all ears elephant
E type
Post  NIGE on Mon Jan 23, 2012 10:09 am
hi it might not be all that amount of work.it might not need welding.i am looking at the most amount of work it will need.i am hoping to get started on cylinder soon .once that is done i can give you more info. i would love to find a royspeed small block manifold and use that.years ago racers used fabricate there own.old tuning manual.26mm amal carb
Post  E type on Sun Jan 29, 2012 12:46 pm
Thanks for info nige going to try the 150 route as it also seems that the lth reed fit with minimal work too
E type
