Difference between cranks and mag housing
Page 1 of 1 • Share •
Hello all,
I believe there are two types of cranks for the Vega 75, early and late and two types of mag housing to suit each crank.
Part No. 20050014 (needle 3 part roller bearing type mag housing) early?
Part No. 20950045 (single ball bearing type mag housing) Late?
How can you tell what type of crank you have and which mag housing suits it. I've been trying to find this info out for a while now.
Cheers all.
Cheers all.
Jools- Posts : 15
Re: Difference between cranks and mag housing
Jools, take a look here
http://forums.lcgb.co.uk/phpBB2/viewforum.php?f=3&topicdays=0&start=25
It might take a while to sift through the thread headlines but i'm sure you will find some answers to your question
Thackers- Posts : 755
its easy, look at your crank (the threaded end) follor the shaft to the main body towards the last inch is it all the same width? if yes then its the 3 part mag housing if not, then its the 1 piece bearing
daz.h- Posts : 866
Spot on photo that Daz, you sure you dont want to do a Luna book
Nice one Daz, thanks for that, I've never been able to find information on the cranks I dont suppose you know the Innocenti part numbers for the two style of cranks?
Jools- Posts : 15
off hand i dont think i do, but i will look later.
daz.h- Posts : 866
mag housings,
daz.h- Posts : 866
