tank springs
tank springs
hi i am after some tank springs, or some thing that will work the same,,cheers in advance
trev- Posts : 4
Re: tank springs
trev, i think scootopia remade some at some stage, worth a try?
Re: tank springs
What the heck are tank springs?
Re: tank springs
The two springs that go over the posts on top of the main frame, then the tank sits on top of those and are compressed by the two bolts which go into the frame posts, securing the tank into place. I think there designed to take out any movement plus you need the four rubber pads to stop vibration/wear between tank and frame. I got mine from Jem i think he makes them. Yet another of those hidden little parts needed to build what has to be one of the most expensive to restore scooters.
Re: tank springs
Thanks David. Your dead right. I wonder what would happen if not fitted?
Re: tank springs
the springs actually fit on top of the petrol tank and under the seat frame, all held down by the bolts passing through the seat frame and into the two seat posts.
Re: tank springs
Did anyone have any joy with these and do they also have rubbers, if so then has anyone got any i can purchase. Thanks
Re: tank springs
I found two springs i need and may have another set on the way so if i do i will et you know and you can have them.
» tank springs
» Vega/cometa parts wanted UPDATE ABANDONED
» Cometa Fuel tank: Screw on oil cap
» Fuel tank
» headlight springs
» Fuel tank
» headlight springs
