fork links
fork links
just putting my forks together and i have noticed how mis matched the fork links are to each other.
was not sure if it was just the set i was using, so checked another set i have as spares and they are also quite a mis-matched set.
i wonder if thats why some people have had trouble centralising wheels.
i certainly wont help.
i will get some pics later and put them on.
Re: fork links
anyone else ever noticed this
Re: fork links
I fitted new bushes to mine on Sat and can't say I noticed anything, I didn't lay them down side by side like that, however, if the forks are straight and you want to the wheel to be pointing in one direction only (ie straight ahead) then the pivot point (bolt) and mounting point ( hub stud) bust both be the same. I'd say ones bent, possibly expplaining the lack of plating ?
THe casa bush kit needed pressing in, and now the front wheel sits straight in the forks, and pivots squarely. We went for a ride out yesterday ( about 35 miles) and it kept up with all the large frame stuff no problem ( In fact I had to slow down and let them catch up at one point!) no dampers fitted yet, not sure I'll bother . . .
Re: fork links
all fits fine now, i'll get some of the cassa plastic bushes for when i do the rebuild, i dont need the insert though as ive used stainless bolts and insert.
nice to see your having to slow down for the other machines, might make them look at luna's in a different light !
Re: fork links
I think its mincing mod syndrome more than scooter innability!
I don't use SS as it has a tendancy to react and seize, fortunately my Lui being an import is entirely rust free, the bolts look like new. washed reassembled and packed with graphite grease should see them fair for a good few years
copper grease is a must with SS ( if it really is, there's a lot of cheap nasty stuff and even if its good there are many different grades . . .many of which do corrode! )
» Fork compressor
» My GP has a wonky wheel.
» Fork springs
» Wanted..Vega parts
» Searching for rubber fork cover
» Fork springs
