75s carb question
75s carb question
Mine came with a 22m jetex chucked in the box and a 22 manifold fitted on the barrel.
my question is,(a) will a 200 manifold fit the barrel, (b)would a 22m jetex work and (c)if you were to replace the lot what would you go for?
plan (c) is my prefered option, engine seem standard and will be left this way.
cheers tone
cheers tone
chepstowtone- Posts : 25
carb
...should run fine with 22 jetex..I'd get on with rest of it and pray to the 'hens tooth fairy' for a standard 20...
i run mine with 22 vhb dellorto and goes well!
joeyfont- Guest
» Carbs and air filter FOR SALE or SWAP
» j125 / tzr 150/ reed valve
» 75s carb float
» Flip top carb
» You reed valve conv guys
» 75s carb float
» Flip top carb
